Date/Time: Fri, 03 May 2024 23:25:41 +0000
LSE data
View Count: 630
[2018-03-19 18:19:47] |
aknsyu71@gmail - Posts: 49 |
Hi, I have LSE (London Stock Exchange) delayed data enbled on my AMP/CQG account but cannot access any of the symbols. AMP has suggested that you would need to enable this?! Is this right? Could you pleas enable it. Many thanks Date Time Of Last Edit: 2018-03-19 20:13:09
[2018-03-19 20:13:00] |
You just need to manually enter those symbols as needed. Refer to: File Menu: Find Symbol (File) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
