Date/Time: Tue, 07 May 2024 09:11:19 +0000
Candlestick/Indicator overlay ordering
View Count: 1298
[2018-03-19 13:56:40] |
User342238 - Posts: 44 |
Hi, I'm having an issue with not being able to see the candlesticks of the main price chart as they are being covered over by the indicators on the chart. How can I place the candles over the indicators? Thanks |
[2018-03-19 14:30:28] |
Xfanman1 - Posts: 320 |
Use this Checkbox in the main study/Settings and Inputs tab window to move the offending elements behind your candles or bars.
StudyBehindCandles.PNG / V - Attached On 2018-03-19 14:30:11 UTC - Size: 30.68 KB - 332 views |
[2018-03-19 19:12:04] |
ah, thanks, so many checkboxes, so little time,, haha
[2018-03-19 20:12:06] |
This is documented here: Chart Studies: Study Display Order Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
