Date/Time: Tue, 07 May 2024 09:42:05 +0000
Loading a DOM configuration
View Count: 965
[2018-03-16 16:30:54] |
pnf101 - Posts: 7 |
I see a button link to "Save Configuration" for the DOM, but how do you "Load Configuration" back into another DOM? Seems I keep having to re-design my DOM.
[2018-03-16 18:56:41] |
Refer to: Basic Trading and the Trade Window: Using and Changing Between Different Trade Window and Attached Orders Configurations Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-03-17 05:33:41] |
pnf101 - Posts: 7 |
I see that, however, if I quit the DOM whilst in the chartbook, and I pull up the DOM again for that chart, I have to go in and change the PnL view from Points to Currency each time. What am I missing here?
[2018-03-19 00:55:26] |
You need to not close the Trading DOM window because otherwise the settings will be lost. Just minimize that window and also save the Chartbook: http://www.sierrachart.com/index.php?page=doc/Chartbooks.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
