Date/Time: Sun, 05 May 2024 22:34:15 +0000
User Question
View Count: 738
[2018-03-14 21:40:36] |
Sierra Chart - Max - Posts: 5605 |
Having a problem with Sierra charts Trade window not staying where you put it. Mine keeps minimizing to upper left corner and very small, have to un attach trade window then re attach trade window to get them back to where the should be, happens whether window on left or right. Sierra Chart Support |
[2018-03-15 18:12:15] |
Mine keeps minimizing to upper left corner and very small, Under what conditions does exactly this happen? What are you doing when this happens?What we want you to do is go to the chart for that particular Trade Window, each chart has its own Trade Window, and select Chart >> Reset Child Windows. If there still is a problem, probably we cannot help with it. In this case refer to: Window Size and Position Not Restored When Opening Chartbook Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
