Date/Time: Sat, 18 May 2024 07:14:16 +0000
F.US.USAM18
View Count: 1067
[2018-03-13 17:29:23] |
User357295 - Posts: 76 |
F.US.USAM18 daily ( or any time frame) chart is bugging ( I'm having 4603 0/32 as last price).
[2018-03-13 19:20:07] |
This is a CQG symbol. It sounds like there is a problem with the CQG data. Provide an image of the chart or Trade DOM, by following these instructions: https://www.sierrachart.com/index.php?page=doc/PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-03-14 10:56:46] |
http://www.sierrachart.com/image.php?Image=152102478594.png
[2018-03-14 14:48:06] |
Xfanman1 - Posts: 320 |
If it's of any help in your problem solving that contract is displaying correctly on my charts (I'm using CQG data also). Scott |
[2018-03-14 18:00:16] |
You need to re-download data from before the data error. Refer to: Data Errors or Spikes in Charts, Flat or Flat Line Graph, Compressed Graph, Errors with Date/Time Values: 2.1.2 Deleting and Re-downloading Data. (Easier and Recommended Method) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
