Date/Time: Mon, 20 May 2024 02:48:50 +0000
Draw Style Dash and Line Style Dash combination not working as expected
View Count: 960
[2018-03-11 16:35:36] |
samual sprat - Posts: 343 |
Hi, I'm using "Period OHLC" study to display the daily open price on my lower timeframe charts. I'm using using it with Draw Style Dash and Line Style Dash with width 1 and that works great. However if I increase the width of the dash above 1, the dash turns to a solid line. Logically it doesn't make sense so I don't think its by design. I can't find any way to make a thick dash line without using Draw Style "Stair Step", but then it looks bad on the chart because of the vertical stair step lines. I don't see why Sierra would allow line width greater than 1 for Stair Step with Dash and not for Dash with Dash I've attached 3 images of a 1hr chart with a daily open loaded to help demonstrate what I mean. 1. Draw Style Dash and Line Style Dash with width 1 (Works great) http://www.sierrachart.com/image.php?Image=1520785308161.png 2. Draw Style Dash and Line Style Dash with width 2 (turns into line) http://www.sierrachart.com/image.php?Image=152078554919.png 3. Draw Style Stair Step and Line Style Dash with width 2 (works as expected) http://www.sierrachart.com/image.php?Image=1520785986827.png My apologies if this is by design and your patience is appreciated. I've tried multiple workarounds and cant find a way to do what I want without using Stair step. Please let me know if there is another draw style to achieve what I need Thanks S Date Time Of Last Edit: 2018-03-11 18:43:11
[2018-03-11 20:34:05] |
Did you ever think of reading the documentation instead of all of this taking your time and our time. This is already answered here: Chart Studies: Subgraphs Tab >> Line Style We can definitely not help you further. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-03-11 21:14:56
