Date/Time: Mon, 20 May 2024 03:33:19 +0000
Spreadsheet Study Question
View Count: 622
[2018-03-08 15:21:16] |
RonW - Posts: 103 |
I am having some difficulty with the Spreadsheet Study. Specifically, the appearances of the subgraphs on my chart seem a little random...sometimes they draw; sometimes they disappear. Can you direct me to an explanation of what might be happening and how to avoid it? Also, and this is additional... I just noticed that if I check hide for some studies in the study window, but leave the spreadsheet study unchecked, the spreadsheet study also does not draw. Is this supposed to happen? Thanks. |
[2018-03-09 06:11:33] |
. Can you direct me to an explanation of what might be happening and how to avoid it? Perhaps this is due to study calculation precedence:Chart Studies: Study Calculation Precedence And Related Issues Also, and this is additional... I just noticed that if I check hide for some studies in the study window, but leave the spreadsheet study unchecked, the spreadsheet study also does not draw. Is this supposed to happen? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
