Date/Time: Mon, 20 May 2024 07:57:39 +0000
How to change the roll over data for futures contract
View Count: 829
[2018-03-08 14:25:26] |
bizywoman - Posts: 6 |
The rollover to ESM8 futures contract is 6 points up in Sierra Chart. The trading room and other traders I follow are using 5 points up as the adjustment amount. How can I change my charts to show 5 points instead of 6 points adjustment? I tried using the Edit>>Adjust Data option but my charts haven't changed. I also tried to Reload and Recalculate but I don't see any changes. |
[2018-03-08 20:41:35] |
Refer to: Continuous Futures Contract Charts: Controlling Rollover Amount for Back Adjustments Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
