Date/Time: Sun, 19 May 2024 23:33:01 +0000
Value Label Only and Hidden DrawStyle
View Count: 1305
[2018-03-02 12:44:29] |
User942837 - Posts: 108 |
Is it possible to not draw anything on the chart and only show the value of subgraph please? Both Ignore and Hidden does not let you to display Value Label. Thanks |
[2018-03-02 16:24:12] |
Xfanman1 - Posts: 320 |
I'd be interested in this too. Especially when using studies that reference other chart studies. Even better if it produced a label I could move or add "too" the main graph somewhere not just the subgraph label. Sorry to piggy back on your post but this would be useful if it's not already possible. If this is outside what you're asking for I'll post a separate question. Thanks -- Scott EDIT Never mind my comments above...for my purposes I just found the Study Settings Text Display for Study does EXACTLY what I needed. Maybe this will help you too as it gives you an adjustable label you can put anywhere on the chart based on the Horizontal and Vertical positions. Date Time Of Last Edit: 2018-03-02 16:57:37
[2018-03-02 19:23:32] |
Yes. Use this particular Draw Style: Chart Studies: Subgraph Name and Value Labels Only (ACSIL: DRAWSTYLE_SUBGRAPH_NAME_AND_VALUE_LABELS_ONLY) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
