Date/Time: Tue, 14 May 2024 16:50:34 +0000
Atomated Trading with 2 copies in use different provider for Datafeed and Broker?
View Count: 1013
[2018-02-20 00:20:02] |
TedMar - Posts: 189 |
My idea : Build Automatic Trading System on IQfeed datafeed and made the Trades with Interactiv Brokers. IB provide poor data for scalping, and in Sierrachart is unposible to connect to two primiery Provider in same Instance. How i can the ORDER Signal (Buy,Sell,Limit,Stop.etc) from Datafeed Instance push to Broker (IB) Instance for real trade? |
[2018-02-20 00:46:34] |
Why do you want to use IQ Feed instead of the Sierra Chart Exchange Data Feed?: Sierra Chart Exchange Data Feed The SC Exchange Data Feed supports full integration with Interactive Brokers: Sierra Chart Exchange Data Feed: Integration with Trading Services This really is the simplest way of accomplishing this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-02-20 00:46:50
[2018-02-20 07:50:34] |
I use IQfeed for other Clients Software in same time tooThe SC Exchange Data Feed supports full integration with Interactive Brokers:
b.) is posible resolve my quest without SC Exchange ?
[2018-02-20 17:42:41] |
OK we understand the need for IQ Feed in this particular case. The solution to this is to use the remote chart data file feature which will require two instances of Sierra Chart. This is documented here: https://www.sierrachart.com/index.php?page=doc/FileMenu.html#FileFindSymbol_OpenChartFromAnotherInstance Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
