Date/Time: Wed, 08 May 2024 01:29:41 +0000
[Programming Help] - Cannot access .csv file symbol with Add Additional Symbol study
View Count: 995
[2018-01-31 22:50:47] |
User953894 - Posts: 58 |
The Add Additional Symbol study does not seem to read data for symbols I've created that have in .csv format. Is that by design? On a related note, I probably could have new records formatted in .scid format as they come in instead of the comma delimited format I currently use. If I did get the formatting done, is adding new records to an existing .scid file just like adding to a .csv file (add the new records to the end of the file)? Thanks. |
[2018-02-01 02:25:40] |
Refer to the Inputs section here about this: Add Additional Symbol: Inputs Refer to the description for Symbol. For importing Intraday data, refer to: Exporting and Importing Intraday Data Files Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-03-22 15:15:55] |
I'm having more critical problems using text files and want to instead go to .scid files. The importing data link is useful, but doesn't explain what I need to know. After I have created the .scid files for custom instruments, I want to update these files every minute or so. Closing my regular broker connection to do this is impractical. Is it possible to add new records to an existing .scid file? (I assume it is, because that is what all data feeds into Sierra Charts do). How is this accomplished without disconnecting from my broker feed? |
