Date/Time: Sat, 04 May 2024 05:52:19 +0000
[Programming Help] - save the drawing as default?
View Count: 1025
[2018-01-26 16:24:04] |
User378082 - Posts: 33 |
how to save the drawing's properties change as default?
360截图20180127002253675.jpg / V - Attached On 2018-01-26 16:23:56 UTC - Size: 21.62 KB - 320 views |
[2018-07-07 11:23:39] |
You can change the default behavior by adjusting the Drawing Configuration that you want to use. You can find the documentation for all of this here: Chart Drawing Tools: Drawing Tool Configuration Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-07-07 11:24:03
