Date/Time: Wed, 08 May 2024 15:51:22 +0000
Line on Close/Open
View Count: 1665
[2018-01-23 00:50:24] |
User360283 - Posts: 440 |
Is there a way to get Line on Close / Open to Autocolor 2 colors based on slope? This would br very useful Thanks |
[2018-01-23 17:56:22] |
This is not directly supported but you could use this particular study: Study Subgraph Reference And then use the Auto Coloring Subgraph setting to accomplish this: Chart Studies: Subgraphs Tab >> Auto Coloring Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-01-23 22:07:50
[2018-01-23 18:00:06] |
Prior post has been updated.
[2018-01-23 20:42:33] |
Sawtooth - Posts: 3993 |
Use could also use the Color Bar Based On Slope study.
[2018-01-23 22:09:35] |
Yes actually that would be true. Initially we thought not because we thought that would be coloring the bars but they want a line. However, since there is only a line for the main price graph that will be colored instead.
