Date/Time: Sun, 19 May 2024 21:02:19 +0000
Horizontal Line/Ray label (tool)
View Count: 1656
[2018-01-22 10:55:44] |
User132748 - Posts: 159 |
Could you consider the option of adding a custom label to horizontal line/ray tool? Also to be accesible via ASCIL. Thanks
[2018-01-22 19:06:19] |
This is already supported: Chart Drawing Tools: Modify Text Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-01-22 21:15:03] |
Oh thanks didnt know that. But how can it be done via ASCIL? Im adding horizontal rays and want to add labels from code. PS: I assume i should set Text property for HORIZONTAL_RAY tool. Date Time Of Last Edit: 2018-01-22 21:27:21
[2018-01-22 21:27:22] |
Refer to: https://www.sierrachart.com/index.php?page=doc/ACSILDrawingTools.html#Text Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
