Date/Time: Fri, 03 May 2024 16:54:24 +0000
User Question
View Count: 839
[2018-01-21 05:50:51] |
Sierra Chart - Max - Posts: 5599 |
Hello, first congratulations for you awesome platform, let me say I do not speak english, so sometimes is confuse to me follow the instructions of your website, I will open an account I have not decided what broker exactly I will use, but it is sure i will use your platform, but before I want to be sure I will be able to set the main resources, I use for my trading volume profiles, number bars ( I knew it as foot print) delta histograms and liquity or DOM histograms. I need you help to set number bars I use two different charts, volume profile and delta profile, looking for imbalances, but I in this setting sometimes I can not see the numbers because the color of background is the same of the numbers, I would to set number bars calculated values, to see the percentage of the delta respect to total volume, I can see the delta in numbers but for me is important to see it in percentage, it is possible? I would to change the color or filled orders in the chart I trade 1 or 2 contracts maximus, so I just attach profit, stop loss and break even, but I am not sure how to set it. Thanks in advance,for you help regards Hello SIERRA team Let me say downloaded tha platform through CANON broker, well it is ok, I am very amazed with your platform and for sure I will use it to trade my real account, but please could you response my questions? I do not speak english, so sometimes is confuse to me follow the instructions of your website, I will open an account I have not decided what broker exactly I will use, but it is sure i will use your platform, but before I want to be sure I will be able to set the main resources, I use for my trading volume profiles, number bars ( I knew it as foot print) delta histograms and liquity or DOM histograms. I need you help to set number bars I use two different charts, volume profile and delta profile, looking for imbalances, but I in this setting sometimes I can not see the numbers because the color of background is the same of the numbers, I would to set number bars calculated values, to see the percentage of the delta respect to total volume, I can see the delta in numbers but for me is important to see it in percentage, it is possible? I would to change the color or filled orders in the chart I trade 1 or 2 contracts as maximum, so I just attach profit, stop loss and break even, but I am not sure how to set it. regards Sierra Chart Support Date Time Of Last Edit: 2018-01-23 15:06:23
[2018-01-23 18:21:16] |
1. With regards to but I in this setting sometimes I can not see the numbers because the color of background is the same of the numbers , you can change the background color and the text color to be different from one another. First, set the option for Use Separate Coloring for Text Coloring Method to Yes. Then change the text colors that are defined right underneath this input. The documentation for this can be found here: Numbers Bars: Use Separate Colors for Text Coloring Method 2. With regards to I can see the delta in numbers but for me is important to see it in percentage, it is possible . Try using the Dominant Side Volume Percent input for the Numbers Bars Text Type. The documentation for this is here:Numbers Bars: Numbers Bars Text Types Otherwise, you can use the Numbers Bars Calculated Values study to place additional information on the graph. You can find the information for this study here: Numbers Bars: Displaying Numeric Information Below Numbers Bars 3. With regards to I would to change the color or filled orders in the chart , refer to the documentation about order fills here: Chart Trading and the Chart DOM: Displaying Order Fills on the Chart 4. I trade 1 or 2 contracts maximus, so I just attach profit, stop loss and break even, but I am not sure how to set it. Attached Orders We will not be responding to any further email questions. They must be posted here. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-01-23 18:25:08
