Date/Time: Thu, 02 May 2024 23:24:53 +0000
Transparent volume bars?
View Count: 1686
[2018-01-19 15:38:49] |
traderacefly - Posts: 57 |
Is there a non-programmatic way to set volume bar transparency like the attached screenshot?
Date Time Of Last Edit: 2018-01-19 15:39:58
Capture601.JPG / V - Attached On 2018-01-19 15:39:22 UTC - Size: 55.31 KB - 449 views |
[2018-01-19 18:54:55] |
No but we could add a Draw Style to do this.
[2018-01-19 23:35:53] |
On the Subgraphs tab for the Volume study, change the Draw Style to Transparent Bar Bottom and then set the transparency level as desired in the Transparency Level for Fill Styles box. The main documentation on the Subgraphs tab can be found here: Chart Studies: Subgraphs Tab The documentation for the draw styles can be found here: Chart Studies: Subgraphs Tab >> Draw Style And the documentation for the transparency setting can be found here: Chart Studies: Subgraphs Tab >> Transparency Level for Fill Styles Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
