Date/Time: Sat, 18 May 2024 20:43:45 +0000
I don't see accurate Daily change in the Replay Chart
View Count: 633
[2018-01-17 07:28:01] |
DevTrader79 - Posts: 44 |
I see daily change displays on the top of the chart header perfectly during the live market. However when I play the replay chart daily change stays 0.0 and the change toggles between -2.00 to +2.00. My question is (a) how to get the exact daily change of the historical data while playing replay chart ? (b) how to control or turn on or off the chart header parameters ? Included a screenshot of the chart with circles. Again great support on sierra charts and love the software. Thanks in Advance |
SierraChartDailyChange.jpg / V - Attached On 2018-01-17 07:25:35 UTC - Size: 466.16 KB - 304 views |
[2018-01-17 22:28:50] |
The daily price change is not supported during a chart replay. (b) how to control or turn on or off the chart header parameters ?
Refer to:Working With Charts: Region Data Line / Chart Header Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
