Date/Time: Sun, 19 May 2024 12:15:19 +0000
[User Discussion] - Time based studies inaccurate on Renko charts
View Count: 1001
[2018-01-12 14:47:24] |
User360283 - Posts: 440 |
Flex Renko 5-4-1 (barSize - TrendOff-RevOff and 5 minute chart enclosed. Note levels for NY Low Study - High Lo for Time Period Renko shows LO at 2769.75 5- Minute shows 268.75 They should be at the same price levels. Thanks |
Attachment Deleted. forSierra.Cht - Attached On 2018-01-12 14:46:11 UTC - Size: 159.89 KB - 282 views |
[2018-01-12 15:03:28] |
Calculations which need to be based on a fixed time are not going to be accurate on Renko charts. There is no further support or comment you will get from us on this. This is now marked as a User Discussion. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-01-12 15:25:22] |
Makes Renkos useless. This really needs to be fixed.
[2018-01-12 19:34:37] |
We updated the documentation for the studies about this.
[2018-01-12 19:45:18] |
I created a work around by using the Stuy Price Overlay from a 5 minute chart. Thanks |
[2018-01-16 05:42:04] |
User978786 - Posts: 1 |
User360283-- How did you do that? Can you share your code?
[2018-01-16 06:21:04] |
Set up a nn-minute chart. On the Renko chart insert the Study/Price Overlay On the Study/Price overly select the nn-minute |
[2018-01-16 09:13:25] |
Yes this is true. You can do it this way. Here is the relevant documentation: Study/Price Overlay Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
