Date/Time: Sat, 04 May 2024 20:01:59 +0000
spreadsheet study same symbol different Chartbook
View Count: 770
[2018-01-10 14:01:08] |
AKR - Posts: 523 |
I want to use a spreadsheet study in a chart and i want it to be in a "separate" spreadsheet. so I made a new chb, put a chart there and spreadsheet study. now in this spreadsheet I see ALL data from studies also from other chartbooks for the same symbol. even in tab1 (for chart #1) the data changes every second from the data of the new chartbook to data of other chartbook with same symbol, as chart #1 does exist in both and both have the spreadsheet study. how can I tell it only to show data from that specific chartbook? |
[2018-01-10 22:35:18] |
It sounds like you just want to use a different named Spreadsheet with the Spreadsheet Study. Here is the setting for that: Chart Studies: Settings and Inputs Tab >> Spreadsheet Name / DLL File and Function Name Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
