Date/Time: Sun, 05 May 2024 17:10:11 +0000
NumberBars Candle Stick format
View Count: 751
[2018-01-10 02:58:22] |
User48942 - Posts: 9 |
Hello Team, I love the number bars study and Sierra Chart for their wonderful work. I was looking in Number Bars settings to see if there is any way to achieve the candle body outline between Bid/Offer instead of X. Please see attached from screen shot. I thin it is from NinjaTrader. |
OrderFlowCandle.png / V - Attached On 2018-01-10 02:58:10 UTC - Size: 29.57 KB - 295 views |
[2018-01-11 01:06:28] |
What Sierra Chart has available, in this regard is documented here: Numbers Bars: Drawing Open to Close Boxes on Side of Numbers Bar You can also change the delimiter as well: Numbers Bars: Numbers Separator Character And here is the Numbers Bars page: Numbers Bars Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
