Date/Time: Wed, 01 May 2024 10:04:03 +0000
One account using a Rithmic feed on 2 computers
View Count: 1194
[2018-01-10 01:41:17] |
User28706 - Posts: 22 |
In the past I have been able to login simultaneously on 2 computers into 1 account using a Rithmic data feed connection. Currently I am not able to do so. Can you help?
[2018-01-10 02:21:02] |
The question we have is whether you are unable to login to the Sierra Chart charting and trading software, or unable to connect to the data feed/trade server. For help to answer this question, please review help topic number 62 here: Software Login or Data Feed Connection Problem Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-01-10 02:42:51] |
I am able to login into both Sierra charting software platforms. However as soon as one of them connects to the Rithmic data feed the other one can not connect. This suddenly happened today. Just yesterday both sierra platforms were able to connect to the Rithmic feed with the same login info simultaneously.
[2018-01-10 02:59:55] |
You need to contact your broker about this. If they cannot solve this, then we suspect the CME is to blame here.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-01-10 03:04:22
[2018-01-10 03:03:06] |
As an alternative use the DTC Protocol Server: Data and Trading Communications (DTC) Protocol Server If you understand that documentation and what that feature is capable of, then good. If not, then it is not something we will help with. But understand the new Sierra Chart agreement which is currently in force between all users and Sierra Chart, means you can be held liable financially for market data violations if we are informed by the exchange of any violation. We have to say this. Refer to the post above as well. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-01-10 03:04:31
