Date/Time: Thu, 02 May 2024 12:13:55 +0000
Alert Sounds
View Count: 4620
[2018-01-03 11:53:06] |
User371906 - Posts: 141 |
Hello, How can I set a different sound (.wav) alert other than the ones provided by Sierra? I have gone to SierraCharts folder AlertSounds and changed the Alert1 to the new .wav and save it with the same name as it was before but the system doesn't use it even when I restart program. Is there a way to be able to do this? Please let me know Regards g |
[2018-01-03 18:24:54] |
Refer to the documentation here: https://www.sierrachart.com/index.php?page=doc/GeneralSettings.html#AlertSoundSettings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-01-03 18:25:02
[2018-01-03 20:30:37] |
