Date/Time: Mon, 29 Apr 2024 03:27:33 +0000
Number of bars study - "candle Width"
View Count: 1901
[2018-01-02 16:37:01] |
User33743 - Posts: 83 |
Hi, Could you tell me where I can setup width for BAR, so it would look like this? https://www.sierrachart.com/images/NumbersBars_img3.png Right now i get result as at the attachment. TY for your help. Best Regards |
Screenshot_1.png / V - Attached On 2018-01-02 16:36:25 UTC - Size: 55.84 KB - 455 views |
[2018-01-02 16:38:58] |
Is this possible also to overlay chart with "candlestick" style? Example at the attachment
Screenshot_2.png / V - Attached On 2018-01-02 16:38:50 UTC - Size: 232.3 KB - 477 views |
[2018-01-02 19:01:59] |
Refer to the instructions here: https://www.sierrachart.com/index.php?page=doc/NumbersBars.php#Scaling Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-01-02 19:03:07] |
To display a candlestick bar as well on Numbers Bars, use this Input: Numbers Bars: Open and Close Marker Style Also be sure to see the prior post. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
