Date/Time: Fri, 03 May 2024 08:17:13 +0000
can I narrow down the space of the TPOs?
View Count: 1327
[2017-12-29 12:55:26] |
User378082 - Posts: 33 |
http://www.sierrachart.com/image.php?Image=1514552029305.png like showed, the space of A,B and C is too wide. |
[2017-12-30 05:06:04] |
Refer to: Working With Charts: Changing Bar Spacing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-01-06 06:57:58] |
I mean the default space. can I change it?
[2018-01-07 01:12:32] |
Yes. Just follow the instructions here to change the bar spacing: Working With Charts: Changing Bar Spacing You need to reduce the spacing. This also applies to TPO charts. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-01-07 01:12:43
