Date/Time: Mon, 29 Apr 2024 04:40:27 +0000
Export VAH, VAL and VPOC information
View Count: 1586
[2017-12-27 20:46:36] |
lex0429 - Posts: 12 |
Is there a way to export the daily VAH, VAL and VPOC values? I am trying to avoid manually putting it into an Excel file to later import into R. Any help would be greatly appreciated. Thanks in advance. If I could export the data for each day, that shows in the "Chart Values Window" that would be a HUGE time saver. Date Time Of Last Edit: 2017-12-27 22:40:42
sierra.JPG / V - Attached On 2017-12-27 22:40:36 UTC - Size: 86.48 KB - 358 views |
[2017-12-28 19:03:46] |
The easiest way to do this is to use the TPO Value Area Lines study on a standard chart: TPO Value Area Lines And then export the data using this function: Edit Menu: Edit >> Export Bar and Study Data to Text File Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-12-28 19:05:58
[2017-12-29 19:05:26] |
Thanks very much for the answer. Have a happy new year!
