Date/Time: Mon, 29 Apr 2024 06:22:22 +0000
Hand tool
View Count: 1545
[2017-12-27 18:39:20] |
User132748 - Posts: 159 |
Was it your intention to change HAND tool button's behaviour? Now it toggles on/off. It's pretty confusing as I have a keyboard shortcut for it (spacebar) and when I want to move the chart sometimes after hitting spacebar Im SWITCHING OFF the hand tool and have to click spacebar again to switch it on. The same behaviour is when I click hand button on toolbar - it toggles hand tool on/off. All other tools can be only switched on which looks like proper behaviour. Could you change it to how it was several builds ago? Thanks |
[2017-12-27 18:58:12] |
Yes it was changed but it is not clear why there is a problem. If it is on, simply do not try to activate it again.
[2017-12-27 20:34:34] |
Well all of us traders have their habits. When I want to move the chart (and I move them a lot) I just hit spacebar and move the chart. I don't bother if the tool is already on or not. And it's very frustrating when it was on and I just switched it off and mouse didn't move the chart. The same idea (using spacebar shortcut to grab and move the chart/canvas) is used in a lot of other programs - Corel Draw, Adobe Photoshop, etc. And in all of them this tool works as kind of monostable relay. Grab and move. I would be very grateful if you could change it back, also because of the fact this new behaviour is different than all other tools in Sierra. Thanks in advance! Date Time Of Last Edit: 2017-12-27 20:34:56
[2017-12-28 19:01:19] |
OK we see. Update to prerelease 1677. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
