Date/Time: Mon, 29 Apr 2024 06:11:37 +0000
Min Value in NBs
View Count: 750
[2017-12-27 07:28:31] |
nicktrader - Posts: 665 |
Pls take a look to the attached pic. There are only marked the option "Highlight Minimum Value". There are a lot of candles marked on a wrong level. Did I make anything wrong? |
Min Value.png / V - Attached On 2017-12-27 07:27:15 UTC - Size: 48 KB - 301 views |
[2017-12-27 17:46:28] |
Refer to the documentation for Highlight Minimum Value In for an understanding of how this works and how to control what is highlighted: Numbers Bars: Highlight Minimum Value In Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
