Date/Time: Sun, 28 Apr 2024 16:08:23 +0000
Software Freezes when setting up Crypto charts
View Count: 2021
[2017-12-24 15:25:31] |
ephi144 - Posts: 54 |
hello there. thank you for supporting cryptos. i have gotten bitcoin and litecoin volume profile charts working. however, when i try ETH USD BITFINIX chart set up the same way. the charts are freezing and i have to 'end task' it. for bitcoin i have set tick size to 30 for litecoin to 1 for eth to 5 (under the chart settings window using F5 key) any idea what i may need to do? i have m.2 drive, 6 core 12 thread CPU, 2 GTX 960s. |
[2017-12-24 22:07:52] |
Here is the relevant documentation for this: https://www.sierrachart.com/index.php?page=doc/Bitcoin.php#VolumeAtPriceStudiesWithCryptoCurrencySymbols Make sure you adjust the Tick Size before using the Volume by Price study on the chart. This is essential. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-12-24 22:08:05
[2017-12-25 11:26:35] |
gomifromparis - Posts: 244 |
Just wanted to take the opportunity to mention you can have a look at the GomMPPro profiler, it's highly optimized and will handle the crypto data on the smallest tick size with no issues on Sierra. https://www.gomicators.com/gommppro Date Time Of Last Edit: 2017-12-25 11:30:37
gommpcrypto.png / V - Attached On 2017-12-25 11:30:34 UTC - Size: 64.14 KB - 335 views |
