Date/Time: Thu, 02 May 2024 20:54:16 +0000
Edit -> Export Intraday data
View Count: 858
[2017-12-23 19:11:09] |
User39772 - Posts: 311 |
Hello, when I export a data file these file can have 5GB or more of data. How/where can I influence the amount of data exported ? I tried to change the chart settings "days to load" etc. but this seems to have no effect on it. |
[2017-12-24 01:38:11] |
You need to use this command instead: Edit Menu: Edit >> Export Bar Data to Text File Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-12-24 01:41:22
[2017-12-24 13:43:39] |
Thank you. I attaced two files. Both contain data from 2017/10/30, 00:00:02 until 2017/11/1, 05:00:19.1 When I load these files into SC via Edit -> Import .. The beginning and ending date/time/price in the chart window (starting on 2017/10/29, ending with different price on 2017/11/1) does not correspond with the data in the file. I would be thankful for any hint how I can solve that. Happy Christmas. |
EURUSD_MC.txt - Attached On 2017-12-24 13:32:03 UTC - Size: 13.66 MB - 303 views Attachment Deleted. |
[2017-12-25 22:50:27] |
Make sure the timestamps in the files are UTC. Although not sure that is relevant to the problem. It does not sound like get but it is something to check anyway. Here is the relevant documentation: Exporting and Importing Intraday Data Files: Import and Load Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
