Date/Time: Sun, 28 Apr 2024 13:22:58 +0000
Daily loading twice
View Count: 748
[2017-12-20 13:16:01] |
Kinobe - Posts: 86 |
hi each time I enter a symbol, the daily chart load and reload 10 sec after. anyway, to make it load just one time? AMD [M] Daily #4 | Reloading chart. | 2017-12-20 08:09:22 AMD [M] Daily #4 | Reloading chart. | 2017-12-20 08:09:31 NVDA [M] 5 Min #1 | Reloading chart. | 2017-12-20 08:09:36 NVDA [M] 5 Sec #2 | Reloading chart. | 2017-12-20 08:09:36 NVDA [M] Daily #4 | Reloading chart. | 2017-12-20 08:09:36 NVDA [M] 15 Min #3 | Reloading chart. | 2017-12-20 08:09:36 NVDA [M] Daily #4 | Reloading chart. | 2017-12-20 08:09:46 Opened cached Intraday file: C:\SierraChart\Data\AMD.scid | 2017-12-20 08:09:50 AMD [M] 5 Min #1 | Reloading chart. | 2017-12-20 08:10:06 AMD [M] Daily #4 | Reloading chart. | 2017-12-20 08:10:06 AMD [M] 15 Min #3 | Reloading chart. | 2017-12-20 08:10:06 AMD [M] 5 Sec #2 | Reloading chart. | 2017-12-20 08:10:06 AMD [M] Daily #4 | Reloading chart. | 2017-12-20 08:10:16 |
[2017-12-20 17:18:56] |
This is because historical data has been downloaded for the symbol. This is normal. Although actually thinking about it some more, we would see that in the Message Log but we do not unless you have cut those messages out. So maybe there is some other cause. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-12-20 17:19:33
[2017-12-20 17:20:07] |
Also, refer to help topic 30.3: https://www.sierrachart.com/index.php?page=doc/helpdetails30.html#h30.3 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
