Date/Time: Mon, 29 Apr 2024 17:43:36 +0000
Number bars data to small different with market delta footprint volume
View Count: 1093
[2017-12-20 05:04:47] |
User245723 - Posts: 6 |
now im use trial package + live LMAX account.. is it trial package + live LMAX account give me real time streaming data feed for spot fx? because i see my number bars volume data too small different with market delta footprint volume data..here i give my screenshot for sierra chart volume data
Capture.PNG / V - Attached On 2017-12-20 05:04:40 UTC - Size: 133.93 KB - 374 views |
[2017-12-20 05:47:08] |
i means small is small volume data..not like other footprint hundred volume(real volume transaction) compare with sierra chart only like tick data.. am i wrong set or its normal? if u can see the picture i attach the volume of gbp/usd achieve 700 lot transaction but sierra chart hard to reach hundred text data volume |
footprint2.png / V - Attached On 2017-12-20 05:42:21 UTC - Size: 98.39 KB - 353 views |
[2017-12-21 13:19:50] |
gomifromparis - Posts: 244 |
you're comparing a 1 min chart with a 1 hour chart
[2017-12-21 18:12:04] |
For an understanding of Forex volume, refer to: http://www.sierrachart.com/index.php?page=doc/ChartDataFiles.html#VolumeData Also take note of what is said in post #3. To change the period of the chart bars, refer to: http://www.sierrachart.com/index.php?page=doc/ChangingPeriodOfBars.php Here is the full documentation for Numbers Bars: http://www.sierrachart.com/index.php?page=doc/NumbersBars.php We cannot help you with post #2. We can only help you with Sierra Chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
