Date/Time: Mon, 29 Apr 2024 06:10:48 +0000
Numbers Bars differences
View Count: 699
[2017-12-19 15:31:57] |
User28914 - Posts: 87 |
I finally got Sierra up,I switched it to another machine and it booted up perfect. I built a few charts using the Numbers bars since thats what I'm use to. What I'm experiencing is data just looks to be off..for example, I'm seeing 0×0 on both the bid and ask for several levels and this has happened on several different bars also seeing ,say 75×16 for 6 price levels and this also happens on different bars with different size but the same type of sequence. Just very difficult to make an analysis of numbers bars with this skewed data.Any Suggestions?
[2017-12-19 17:39:38] |
Follow the instructions here for this: Numbers Bars: Zero Volume Values and Repeating Volume Values (ZeroVolumeValuesAndRepeatingVolumeValues) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
