Date/Time: Fri, 03 May 2024 00:53:47 +0000
Automatic retracement/projection
View Count: 914
[2017-12-17 21:17:05] |
xroads - Posts: 5 |
The study allows for the input in minutes. Therefore, I am assuming that if I set it at '1440' minutes; Calculation method set at 'retracement'; New period at day session start set to 'no'; Calculation reference value set to 'automatic'; Chart Settings...Advanced Settings to include 'columns with no data', Chart Settings Start Time:18:00 EST, End Time:17:59:59, the result should ,in theory, provide me with a calculation that references the high and low for an ongoing 24 hour period. Or, alternatively, if I set it to '3600' minutes,it should automatically reference the high and low of the last 2.5 days. Am I mistaken in my assumption, because it does not appear to function accordingly ?
[2017-12-18 19:50:42] |
the result should ,in theory, provide me with a calculation that references the high and low for an ongoing 24 hour period. Or, alternatively, if I set it to '3600' minutes,it should automatically reference the high and low of the last 2.5 days. This will not be the case. The chart will be divided up into 24 hour or 3600 minute segments which are going to be aligned to the Session Times and a common point of reference. We will make sure the documentation explains this clearly.If you still need more help, then refer to the documentation for this study here: Auto Retracement/Projection Tell us in detail the specific calculation that you are looking for. And provide us an image of a chart showing the 24-hour data for a particular day and the particular result you are looking for from that. We will then need to get your chart by following these instructions here: Support Board Posting Information: Providing Chartbook with Only a Single Chart We can then look this over. Otherwise, it is not possible for us to answer the question. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-12-19 19:17:18] |
The relevant documentation is here: Common Study Inputs: Time Period Unit Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
