Date/Time: Sun, 28 Apr 2024 05:29:46 +0000
Partially data missing
View Count: 779
[2017-12-17 20:53:53] |
Frank Ace - Posts: 12 |
I do have data missing every time when Rollover happens. Here is the CQG data feed I have for last several days with 1000 Volume Chat http://www.sierrachart.com/image.php?Image=1513543475148.png Here is TD with Sierra data feed on 1000 volume chart http://www.sierrachart.com/image.php?Image=1513543838293.png Both chart same setting with same scale, the difference shows that data is missing somehow, Can you help me to fix this problem? |
[2017-12-17 22:03:47] |
First refer to the information here to understand what contract month you are looking at, at each point in the chart: Continuous Futures Contract Charts: Displaying Rollover Transition Times and Contract Months And then follow the instructions here: Continuous Futures Contract Charts: Re-Downloading Continuous Futures Contract Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-12-17 22:04:01
