Date/Time: Thu, 02 May 2024 01:38:38 +0000
CL did not rollover today
View Count: 861
[2017-12-15 14:40:11] |
User571376 - Posts: 1 |
Hello, today CL did not rollover to the new contract, even though i have set the chart to 'date rule rollover - back adjusted'. I had to manually select the G-contract. How come? This is the first time I have this kind of problem. Thanks for your help. Daniel |
[2017-12-15 15:42:10] |
lpfin123 - Posts: 59 |
I had the same issue. Chart settings set to "automatic rollover Futures Symbols" and Global Settings/General Settings/General 4 to "Detect Rollover of Current Futures Contracts Symbols Based on Real Time Volume" Thank you |
[2017-12-15 17:48:22] |
This is because the date-based rollover rule has not yet been met for that contract. Refer to: Chart Settings: Automatically Rollover Futures Symbol (Chart >> Chart Settings >> Symbol >> Symbol menu) In regards to: "Detect Rollover of Current Futures Contracts Symbols Based on Real Time Volume" Refer to: General Settings Window: Detect Rollover Of Current Futures Contracts Symbols Based On Real Time Volume (Global Settings >> General Settings >> Charts >> Symbol) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-12-15 19:40:16] |
We do see a problem where "Detect Rollover of Current Futures Contracts Symbols Based on Real Time Volume" is not giving any notice with CLF18 today. We have fixed that and will have a new release out by Monday.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-12-15 19:40:34
