Date/Time: Sun, 28 Apr 2024 22:27:31 +0000
Interactive Brokers open orders
View Count: 864
[2017-12-14 20:38:38] |
User995992 - Posts: 5 |
Hi, I'm currently using SC with IB and don't see my open orders and positions on charts and trade log. is that a limitation? Thanks |
[2017-12-15 19:34:27] |
Make sure Sierra Chart is connected to Interactive Brokers. Follow the instructions here: Interactive Brokers Trading Service: Setup Instructions And were these orders entered from Sierra Chart? In regards to the Trade Position data, refer to: Interactive Brokers Trading Service: Trade Position Line or Quantity Disappearing or Displaying Zero Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-12-19 14:48:07] |
No, the orders were entered from IB client...
[2017-12-19 19:30:43] |
Accessing All Trade Orders from TWS: If you want to have access to all trade orders entered from TWS as well as orders entered from Sierra Chart, then you will need to set the Global Settings >> Data/Trade Service Settings >> Service Setting >> Instance Client ID setting to 0.
After changing that setting, reconnect: File Menu: Procedure to Reconnect to the Data and Trade Servers Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
