Date/Time: Sun, 28 Apr 2024 13:00:42 +0000
Disable keyboard for chart
View Count: 954
[2017-12-14 16:34:10] |
sampater - Posts: 243 |
How can I disable the possibility of accidentally switching a symbol using the keyboard?
[2017-12-14 17:45:18] |
Disable this: General Settings Window: Support Symbol Entry from Chart Window (Global Settings >> General Settings >> Charts >> Symbol) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-12-14 18:59:19] |
This option was disabled, but the symbol has already changed twice... It happen if did something wrong during place a text tool but I do not remember exactly how. |
[2018-01-20 20:00:00] |
It happened to me several more times, and finally I came when it happens: If i press "Shift" + "=" or "-". How to turn it off? |
[2018-01-21 17:59:38] |
These are shortcuts from the Chart --> "Next File" and "Previous File", that can not be turned off, even if they are changed to others on the Global Settings --> Customize Keyboard Shortcuts.
