Date/Time: Thu, 02 May 2024 15:45:56 +0000
Formula / study to caluculate gradient
View Count: 955
[2017-12-13 17:48:18] |
bala - Posts: 74 |
I see that you color subcharts based on gradient. I need a formula to compute a gradient as opposed to slope. Could you please post your formula or the study where I can get the code? Thanks |
[2017-12-13 19:15:35] |
I see that you color subcharts based on gradient. We do not know what you are referring to.
[2017-12-13 19:25:26] |
bala - Posts: 74 |
Use study 'Moving average difference'. It gets plotted in region 2. One of the options for 'AUTO COLOR' is based on the gradient. I was referring to this option. I am trying to compute the GRADIENT of a curve as opposed to SLOPE. I was wondering if I can borrow from your computation. |
[2017-12-13 19:54:24] |
We can only refer you to the available documentation which is here: Chart Studies: Subgraphs Tab >> Auto Coloring Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
