Date/Time: Sat, 04 May 2024 16:00:35 +0000
Alert on Delta Divergence
View Count: 2761
[2017-12-12 09:06:49] |
s291117 - Posts: 28 |
Hello Support, i would like to know if it is technically possible to define an alert when these 2 conditions are met ? UP BAR + NEGATIVE DELTA or DOWN BAR + POSITIVE DELTA ? (Please see attached screenshot illustrating the first situation.) Besides, i wanted to have confirmatinon that it is nearly impossible to have a countdown on a rangebar chart, right ? It is not possible to have any clue when a period on a footprint will end. Thanks ! |
sc_OneUp_CLF8_121217_Footprint_5R_Delta-Divergence.jpg / V - Attached On 2017-12-12 09:01:25 UTC - Size: 980.79 KB - 1358 views |
[2017-12-12 19:03:09] |
You can certainly write an Alert Formula to accomplish this. Refer to: Study/Chart Alerts And Scanning You will want to use these special functions to access the Volume at Price data: Study/Chart Alerts And Scanning: Special Functions And refer to: Numbers Bars: Referencing Numbers Bars Calculated Values Subgraphs in Alert Formulas Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-12-12 19:03:15
[2017-12-12 19:06:08] |
Refer to the response above. Besides, i wanted to have confirmatinon that it is nearly impossible to have a countdown on a rangebar chart, right ? It is not possible to have any clue when a period on a footprint will end. The Countdown Timer does work with Range bars, but it does not indicate when a new bar will start unless you use this Bar Period Type: Chart Settings: Intraday Chart Bar Period >> Bar Period Type >> Range Per Bar - New Bar on Range Met (in ticks) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-12-12 19:06:36
