Date/Time: Wed, 01 May 2024 01:36:01 +0000
Manually Closing orders opened by a strategy
View Count: 1074
[2017-12-08 18:42:06] |
User99735 - Posts: 234 |
Hi, Have a strategy which opens orders with OCO exit orders attached. If any position is closed manually, subsequent BuyEntry and SellEntry orders return with Error Code -8998, Error String: Order entry skipped because full recalculation. Is this normal behaviour?? Is it possible to keep the strategy 'active' and place new orders, even after a position has been closed manually?? Regards Vivek |
[2017-12-08 23:01:44] |
If any position is closed manually, subsequent BuyEntry and SellEntry orders return with Error Code -8998, Error String: Order entry skipped because full recalculation. Working with ACSIL Arrays and Understanding Looping: When the Study Function is Called Closing a position does not result in a full recalculation. That does not make sense. There must be some misunderstanding on your part or doing something to cause a full recalculation. Is it possible to keep the strategy 'active' and place new orders, even after a position has been closed manually?? If you close a Position, any Attached Orders associated with it, should be canceled. Ultimately you can do whatever you want. You really should not have to ask us. You need to figure this out. You should not have to ask us about this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-12-08 23:03:24
