Date/Time: Mon, 29 Apr 2024 06:52:53 +0000
Resize window with changing scale
View Count: 1688
[2017-12-08 17:52:32] |
User161390 - Posts: 16 |
Is there a way to resize a chart window without changing the vertical price scale? I want to be able to maximize and restore windows without the scale changing.
[2017-12-08 18:37:49] |
This is hard for us to answer from our perspective. We do not know how it is changing and what you are expecting. The first thing we recommend you do is select Chart >> Reset Scales. And make sure it uses an Automatic Scale Range: Chart Scale and Scale Adjusting: Opening the Scale Settings Window for the Main Price Graph Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-12-08 18:38:41
[2017-12-08 19:10:14] |
I have attached before and after files. I used file upload instead of the screenshot instructions so you can see the desktop and window size. See how after I resize the window (from large to small), the scale changes and everything is compressed vertically. I want to resize the window without the scale changing. I have tried various scale range settings, but none seem to affect the behavior when resizing the window |
beforeResize.PNG / V - Attached On 2017-12-08 19:07:18 UTC - Size: 244.62 KB - 400 views afterResize.PNG / V - Attached On 2017-12-08 19:07:25 UTC - Size: 1.2 MB - 429 views |
[2017-12-08 22:26:52] |
The behavior you see is certainly correct.
