Date/Time: Sun, 19 May 2024 02:58:05 +0000
Date range for historical charts not correct (1025)
View Count: 1230
[2013-09-17 02:08:48] |
joshtrader - Posts: 442 |
It seems that with a historical (daily) chart, if a date range is specified, the chart will begin correctly with the begin date, but it still plots data up to the current day, and does not end with the end date that is specified. For example, using 1/1/2012 to 12/31/2012 still plots data up to today, 9/16/2013.
Date Time Of Last Edit: 2013-09-17 02:09:22
[2013-09-17 02:15:55] |
This is true. An End Date is not supported with historical daily charts yet.
