Date/Time: Sun, 28 Apr 2024 18:39:22 +0000
Account not specified error coming up when placing orders with interactive brokers
View Count: 869
[2017-12-06 17:25:51] |
User276793 - Posts: 47 |
(in Canada) I have a margin account and a TFSA account with interactive brokers. When I place an order on futures using Sierra I get the error account not specified. Is there a way to specified the account I with to place trades in? thanks |
[2017-12-06 18:16:49] |
There should never be a case where the Trade Account is not specified with an order to Trader Workstation. Make sure the correct Trade Account is selected on the Trade Window for the chart: http://www.sierrachart.com/index.php?page=doc/TradeWindow.html#SelectingTradeAccount If you still have a problem follow the instructions here to provide the current TWS log file to Interactive Brokers support so they can see what the problem is: http://www.sierrachart.com/index.php?page=doc/InteractiveBrokers.php#ProvidingTWSLogFiles Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-12-06 18:39:53] |
Ahh i see it now. thank you for the help, problem solved!
[2017-12-06 18:58:06] |
OK that is good.
