Date/Time: Sun, 28 Apr 2024 22:30:08 +0000
Global Profit/Loss Management Tool
View Count: 1617
[2017-12-06 00:56:29] |
User713273 - Posts: 409 |
I update to version 1659 and am having trouble reseting my daily PnL. Curently I have Daily Stats Reset Time set to end of trading 13:59:59 MST. Anything I'm missing here?
[2017-12-06 19:36:13] |
Here is the relevant documentation for Daily Profit/Loss: http://www.sierrachart.com/index.php?page=doc/DailyProfitLossValue.html You can see all of the Daily Profit/Loss values on the Trade Statistics for Charts tab: http://www.sierrachart.com/index.php?page=doc/TradeActivityLog.php#TradeStatisticsForChartsTab The Daily Profit/Loss reset for each chart is not going to automatically occur at a fixed time immediately across all symbols. It would only be when the particular symbol has a trade or quote update in the new trading day. We will see if we can improve upon that. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-12-10 22:19:56
[2017-12-06 23:48:25] |
We are going to have a solution implemented in the next release.
[2017-12-10 01:48:51] |
Hi Downloaded 1663. Still having issue with reset due to Global profit/loss reset. Only chart I have open is nflx Profit management: Daily Net P/L = 178.74. Profit value of 110.00 has been met. Positions will be flattened when the Daily Net P/L <= 220.00. | TradeAccount: U2095424 | 2017-12-09 18:40:34 Profit management: Daily Net P/L = 178.74. Profit value of 220.00 after initial trigger of 110.00, has been met. Flattening all Positions now. | TradeAccount: U2095424 | 2017-12-09 18:40:34 Profit/Loss management: Trading is now locked until the next day according to the global time zone setting. | 2017-12-09 18:40:34 * |
Private File |
[2017-12-10 22:19:42] |
We are not sure what it is you are trying to express in post #4. We see the Daily Profit/Loss value at 0 for each of the charts in the attached screenshot.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-12-10 22:20:29
[2017-12-18 16:25:40] |
The problem lies in the fact that the PnL from past trading days is being used in the Global Profit/Loss tool in future trading days when trading the same symbols. Which in turn does not allow me to use the Global Profit/loss tool. It would be key to only use the current trading day only. I have attached screenshots for review.
Private File Private File |
[2017-12-18 18:19:28] |
The Open Profit/Loss is still going to be used in the calculation if that is what you are referring to. If the Open Quantity is wrong on the Trade Stats for Charts tab, then refer to the instructions here about this: https://www.sierrachart.com/index.php?page=doc/TradeActivityLog.php#TradeStatisticsForChartsTab_ResettingData_InaccurateValues Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
