Date/Time: Mon, 29 Apr 2024 07:51:31 +0000
A bug in Current Price Line study
View Count: 945
[2017-12-05 15:19:53] |
User353585 - Posts: 66 |
If I use the Current Price Line study with a (intraday)chart that has less than 40(-ish) bars, the study doesn't appear on the screen. I've tried to set things differently, but nothing seemed to work. I think it's a bug. please take a look into this. thanks. |
[2017-12-05 19:27:39] |
We tested this and we do not see any problem. There really could not be a problem like this in the study. It does not make any sense. Follow the instructions here to reset the study back to default and add it back to the chart: Chart Studies: Resetting Default Study Settings For an Individual Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-12-05 19:28:08
[2017-12-06 03:37:51] |
OK Thanks. I found out that this problem happens with my preferred settings. I prefer the prices line sticks out to the right side. Is there any way that I can make it work with less bars? (I toggle overnight session very frequently and I want to save some loading time) I attach the images. the only difference between the two charts is the loaded amount of days. http://www.sierrachart.com/image.php?Image=1512531258310.png http://www.sierrachart.com/image.php?Image=1512531220895.png *Added note: Even if I use the DEFAULT settings, it doesn't show in 1-0-0 intraday chart which I use. I can only see a tiny dot there. http://www.sierrachart.com/image.php?Image=1512533108546.png Date Time Of Last Edit: 2017-12-06 04:20:44
[2017-12-06 19:24:19] |
We are checking on this and will resolve it.
[2017-12-06 19:46:44] |
We cannot reproduce this problem. When you have the problem attach the chart following these instructions here: https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-12-06 19:48:28
