Date/Time: Sat, 27 Apr 2024 22:35:00 +0000
Why can't I see evening session data in my interday charts?
View Count: 934
[2017-12-04 21:34:27] |
User511364 - Posts: 7 |
I think I've set this up to see the evening session data, but it's not showing up. I keep typing interday when I'm talking about intraday. Date Time Of Last Edit: 2017-12-04 21:56:43
[2017-12-04 22:07:20] |
Make sure the Session Times for the chart are set to include the full 24 hours of trading. Refer to this page: Chart Session Times Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-12-05 00:03:56] |
I've tried all the various setting for 24 hour session start and stop. The chart behaves as if the historical data service is not providing the evening session information at all in the data stream. Is there some setting to enable 24-hour data download that I'm not seeing? Maybe I'm trying to see data that doesn't exist in the data stream. Is evening session price and volume information available in historical data for NYSE-traded stocks?
[2017-12-05 00:21:21] |
I think this setup that I'm using is exactly what is suggested in the documentation:
SierraChart Session Settings.png / V - Attached On 2017-12-05 00:20:25 UTC - Size: 234.47 KB - 253 views |
[2017-12-05 01:10:46] |
The Chart Settings you show in post #4 is for a stock. We looked at that stock and there really is very little evening trading. Also the evening session begins at 16:00:00. Every stock is going to be different in regards to pre-and post-market trading. The pre-and post-market data if they exist, is always downloaded. There is nothing special to do in regards to that. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-12-05 14:02:36] |
It seems I was using a poor example. When I charted AAPL it became clear. Thanks for your help. Unfortunately, the only way I can get less stupid about this is to ask stupid questions. Cheers! |
