Date/Time: Thu, 02 May 2024 12:59:41 +0000
Showing pointer on all different time frame multi windows
View Count: 2823
[2017-12-04 13:08:16] |
User164231 - Posts: 278 |
Hi, How do I set the pointer to show up and move in the same point of time in different time frame charts? Example; I have 4 multi charts in a single window in 1min, 5min, 15min and 1/2 hour. When I move my pointer on either chart, the rest will also have a pointer that move to the exact point in time. Thanks. |
[2017-12-04 16:28:14] |
phaedonk - Posts: 350 |
I'm guessing you are talking about Tools-Global cursor on. This is about the crosshair though.
[2017-12-04 18:08:13] |
Apparently you are referring to the Chart Values tool: Chart Drawing Tools: Chart Values/Crosshair You need to enable the Global Cursor: Chart Drawing Tools: Global Cursor (Tools >> Global Cursor On) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-12-05 07:11:33] |
Hi, How do I center all cross hairs on the center of all charts while moving on either chart? As it is now the larger time frame is always on the extreme right and I can't really see much when I am scrolling forward on smaller time frame. I saw this; "Center Bars to Global Cursor Crosshair" Chart Drawing Tools but it did not provide much info. Date Time Of Last Edit: 2017-12-05 09:08:22
[2017-12-06 17:27:48] |
John - SC Support - Posts: 31293 |
Turn on the option Tools >> Synchronize Charts, when using the Global Cursor. You can find the documentation here: http://www.sierrachart.com/index.php?page=doc/Tools.html#SynchronizeCharts For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-12-06 17:50:53
