Date/Time: Fri, 03 May 2024 03:47:36 +0000
settings for Chart Drawing Alert
View Count: 1107
[2017-12-04 08:28:44] |
EuropeanTrader - Posts: 290 |
Hi, how can I set these settings different by default? See attached Thank you |
ScreenHunter 790.jpg / V - Attached On 2017-12-04 08:28:35 UTC - Size: 96.93 KB - 295 views |
[2017-12-04 19:01:59] |
Refer to: Chart Drawing Tools: Configuring a Default Chart Drawing Alert Condition Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
