Date/Time: Sat, 27 Apr 2024 11:29:20 +0000
New Study Summary Window
View Count: 19347
[2017-12-21 02:24:05] |
sampater - Posts: 243 |
Also, we decided that as far as including hidden Subgraphs, that will be an option. Not by default.
In the prerelease 1671, if i add a new study, hidden Subgraphs still have the Include in Summary option enabled by default.
[2017-12-21 02:28:54] |
Small issue: The option Include Hidden Subgraphs works but there is not visible "check" in the Settings tab if it is enable. |
[2017-12-21 04:38:55] |
In response to post #49 here is the documentation: ACSIL Interface Members - sc.Subgraph Array: sc.Subgraph[].IncludeInStudySummary In response to post #50, this will always be the case. In response to post #51, this is resolved. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-12-21 21:00:26] |
Sierra Chart, Can you add an option to hide displaying a Study Name in the Study Summary Window? |
[2017-12-21 21:15:48] |
So you mean you just want the Subgraph names and not the study names?
[2017-12-21 21:29:00] |
Yes, i want to see only the Subgraph names.
[2017-12-21 23:02:03] |
Currently, if the Alert Condition Formulas in a study is TRUE, then there is highlighted all cells belong to all subgraphs from this study. So, can you change/add option so as to highlighted only one cell that belongs to the subgraph where occur the Alert? I would like to know exactly which subgraph the alert comes from. |
[2017-12-21 23:02:59] |
Alerts are not specific to individual Subgraphs but to the entire study itself. This is something we cannot do.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-12-22 02:40:50
[2017-12-22 00:16:15] |
I understand. And, can you add a possibility to highlighted the background of a study by ACSIL without using the Alert Condition Formulas? And additionaly a possibility to set color of the background regardless of other studies and charts? |
[2017-12-24 21:09:26] |
gayer2428 - Posts: 75 |
As a follow-up to #58 above, please consider making the color background (generated on individual charts based on alert conditions) appear on the Study Summary Window (SSW). It would be nice to be able to just capture the generated colors on the SSW without any additional SSW alert settings (instead of 0 or 1). Please see screenshot (attached). Thank you. http://www.sierrachart.com/image.php?Image=1514149705784.png Date Time Of Last Edit: 2017-12-24 21:14:08
[2017-12-24 21:39:33] |
And, can you add a possibility to highlighted the background of a study by ACSIL without using the Alert Condition Formulas? consider making the color background (generated on individual charts based on alert conditions) appear on the Study Summary Window (SSW). It would be nice to be able to just capture the generated colors on the SSW without any additional SSW alert settings (instead of 0 or 1). Do you mean when the Color Background Based on Alert Condition study is returning TRUE/1 for the last chart bar, that you want the background coloring on the Study Summary window for its Subgraph to match the coloring used by that Study Subgraph?
[2017-12-24 22:51:32] |
Precisely, yes. The Summary Study Window will simply capture the background color (Color Background Based on Alert Condition study) already generated by alert conditions on the chart. Thank you.
[2017-12-25 20:14:48] |
OK, we can support this for the Color Background Based on Alert Condition study.
[2017-12-26 15:56:34] |
Sierra Chart: This is already supported by using sc.SetAlert(). I can't find any documentation about it, so probably i was not enough precisely. I meant to add a possibility to highlighted the background of a study (and the best only one subgraph) in the Study Summary Window by ACSIL, without using the Alert Condition Formulas on the Alerts tab in the Study Settings window for the study. Also, I would like that when the highlighting of the background in the Study Summary Window is triggered then no message is added to the Alerts Log. Argumentation: I have studies that use function sc.PlaySound for adding my special text messages to the Alerts Log without any standard messages. And if a standard message is added eg. by the Alert Condition Formulas then it disturb these my text messages. Also, It would be excellent to be able to set any color of the background in the Study Summary Window by ACSIL if the highlighting of the background in SWW is triggered by ACSIL. Thank you |
[2017-12-26 21:49:44] |
You can do alert background highlighting in the Study Summary window by using sc.SetAlert with the associated study. Refer to the documentation for that function. The requests in post #63 is beyond the bounds of what we are willing to get involved with. This is getting distant from the Study Summary window intent. We will wait a few months and wait for more feedback and reevaluate at that time. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-12-26 21:52:05
[2017-12-27 12:29:10] |
infpz - Posts: 826 |
Is the function described in post #62 available without the use of ASCIL? See attached, this is a good example of how it would be useful to use the colors from the study to paint the Studu Summary. The color background studies in this image are blue, red, and grey - but the "true" alert is only blue.
Date Time Of Last Edit: 2017-12-27 12:56:57
Image 44.png / V - Attached On 2017-12-27 12:56:49 UTC - Size: 162.73 KB - 521 views |
[2017-12-27 17:44:34] |
Is the function described in post #62 available without the use of ASCIL? Yes this will be the case when using Color Background Based on Alert Condition study.This will be out in the next release. Or may have already been released in the latest prerelease. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-12-27 23:55:43] |
I have already read this documentation (sc.SetAlert()) several times and found NOTHING about how to highlighted the background of the Study Summary Window by using sc.SetAlert. Maybe I do not understand something, so could you quote the right fragment that describes how to do it? |
[2017-12-28 02:24:15] |
OK now we understand what you are asking about. The Study Summary window will will use the set "Study Summary: Alert True Background" color for the displayed study Subgraphs for a study included in the Study Summary window, when the Alert Condition (alert state) is true for a study. An ACSIL study can set the alert state for it to true for the last bar by using code like the following. This assumes Automatic Looping is being used: if (sc.Index == sc.ArraySize -1)
sc.SetAlert(1); The if statement is not really necessary but it makes it much more efficient. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-12-28 02:25:12
[2017-12-30 11:41:44] |
Zdislav - Posts: 73 |
Hi Support. I would like to ask if the values from Study Summary Window will be accessible in ACSIL? Thanks. Z. |
[2017-12-30 22:11:49] |
We do not understand post #69 because the values of study Subgraphs have always been accessible from ACSIL: ACSIL Programming Concepts: Using or Referencing Study/Indicator Data in an ACSIL Function Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-12-30 22:11:59
[2018-01-01 20:16:31] |
Well, I hope in better way of synchronizing data across multiple chart types and timeframes as this is all stored all in one place... sort of. Study price overlay does not work as expected in this matter. For example, in case if I want to read only the last value, I need to read the whole array. I was hoping in reading just the actual value from the Summary Window instead of several arrays of values... hope this makes my dumb question more clear. Z. Date Time Of Last Edit: 2018-01-01 20:20:58
[2018-01-01 20:42:56] |
This is still not making sense to us because this is so simple and straightforward. To do this, refer to:ACSIL Programming Concepts: Using or Referencing Study/Indicator Data in an ACSIL Function It is fine to access the whole array. You then just simply access the last element at sc.ArraySize -1 (assuming the study is from the same chart). It is all very efficient. This is what the study summary window does internally. And here is the documentation to access studies on other charts: Referencing Other Time Frames and Symbols When Using the ACSIL: Referencing Data from Other Time Frames By Direct Referencing of the Other Timeframe Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-01-01 21:01:00
[2018-01-04 16:31:57] |
User661281 - Posts: 11 |
Is there a way to get the Study Summary Window to display text? Tried TextDrawStyleText but it just displays the data plot[sc.Index] (currently just a value of 1 to get the text to draw). This would be a great addition to the tool so we could mimic TradeStation's RadarScreen. Seems like it should be do-able since the Name column displays texts, I just can't figure out how to make an indicator. Date Time Of Last Edit: 2018-01-04 17:12:06
[2018-01-04 17:26:25] |
It would be great to be able to display the text in the Study Summary Window !
[2018-01-04 18:10:44] |
So you are saying you want to see the text which is displayed by this particular Draw Style?: Chart Studies: Text (ACSIL: DRAWSTYLE_TEXT) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-01-04 18:11:06
