Date/Time: Sat, 04 May 2024 04:26:19 +0000
Copy chart drawings from other charts
View Count: 1205
[2017-11-20 08:46:20] |
User514370 - Posts: 62 |
Hello, I am using "Copy chart drawings from other charts" (see pic), specifically with simple tool like "Vertical Line Tool". But I do not see this vertical line on other charts in Regions, just on the price chart. Is there any way how to achieve it? Thank you. |
[2017-11-20 20:29:43] |
Make sure Options >> Draw Within Chart Region is disabled for that drawing. Refer to: Chart Drawing Tools: Vertical Line Configuration Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-11-20 20:29:53
